Problem moving clips in the Timeline
COW Forums : Autodesk Smoke
ian sparks
on Apr 23, 2015 at 10:02:22 pm
There is a problem I have been running in to when trying to move clips around in the timeline. Usually it's when trying to move multiple video and audio clips at one time. If I use the "W" shortcut to select multiple clips, one of them will have a greyish tint while all the others have a blue tint (selected). When they are highlighted blue, they should be able to move freely. Is there a solution for selecting multiple clips to make sure they are all blue?
Grant Kay
Re: Problem moving clips in the Timeline
on Apr 24, 2015 at 12:48:39 pm
The “Edit” button is enabled on an Audio Gain Timeline FX. You need to turn it off to be able to perform editorial operations.
Hope this helps.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
