Key in timecode in action not working
COW Forums : Autodesk Smoke
Daniel Burrell
on Apr 10, 2015 at 2:07:37 pm
I am trying to time some things in Action, and I have all of the timecodes recorded for when certain things take place. When I key in the timecode that I want to jump to in the timecode window to the left of the timeline display (under all of the play/pause/keyframe buttons), it jumps to the last available frame. The keyframe that I am trying to navigate to is within the action clip, so I'm not trying to key in a frame that is not available. Right now i'm left to manually scrubbing to the frame and using the arrow keys to get exactly where I need. Adding and subtracting frames works fine to jump forward and backwards by a number of frames(+15 frame or -15 frames), but keying in the exact timecode that I want to jump to doesn't work, it just jumps to the last frame. This was working fine yesterday, and have just started having this problem this morning. I have restarted smoke, but that didn't fix it.
