Sony F65/F55 raw clips in Smoke on Mac
COW Forums : Autodesk Smoke
Neil Sadwelkar
on Feb 23, 2015 at 2:39:46 am
Starting out on Smoke on Mac.
When I open Sony F65/F55 raw files (.mxf), they look all crushed like there was a wrong LUT applied. Same clips look fine in Resolve on Mac. So what's the appropriate way to fix this?
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
Grant Kay
Re: Sony F65/F55 raw clips in Smoke on Mac
on Feb 23, 2015 at 9:20:32 am
Hi Neil,
In the MediaHub, switch to the FORMAT SPECIFIC tab. It usually defaults to "metadata". Click the metadata button and change it to "debayer". There should be some options for you to try out to get the clip looking correct.
The other thought is the colorspace you want to use. Log or Lin for the footage as well as a LUT for the interface to display the footage correctly.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
Josh Spivack
on Feb 25, 2015 at 8:45:26 pm
We are preparing to receive raw clips shot at 8k (ouch!) from the Sony F65. Will my Smoke 2014 be able to handle this at full debayer?
Josh
David Jahns
on Mar 3, 2015 at 2:17:58 am
I've not had great results with Smoke 2013/15 and f55. I've always had to run it through resolve for a first pass.
But you guys should check out this thread:
http://forums.autodesk.com/t5/general-discussion/color-space-for-sony-f65/t...
You might have better luck on the current version. Smoke will choke on the 8k for sure. Good time to learn proxy workflow.
David Jahns
Joint Editorial
Portland, OR
