problem importing pictures
COW Forums : Autodesk Smoke
Daniel Burrell
on Feb 4, 2015 at 4:01:40 pm
I am having a problem importing photos. I have 105 photos that I Need to import, and when I drag and drop into the library, or go into mediahub, it only recognizes 3 photos. They are identically formatted, I have even batch processed them through adobe fireworks as Jpegs, and it still only recognizes 3. The file name format is just 1.jpg through 105.jpg. This has been a pretty consistent problem for me. Any thoughts?
moody glasgow
Re: problem importing pictures
on Feb 4, 2015 at 5:00:37 pm
Did you check to see if you are importing the images as a sequence?
The Smoke will default to seeing the images as a sequence instead of a bunch of individual files.
moody glasgow
vfx superisor / flame artist
Sascha Haber
on Feb 4, 2015 at 5:04:31 pm
Yes, get a file renamer, make them a family with differently names members.
Also if you do numbering don't forget to add correct padding
Example Family : Image-AAA.jpg, image-AAB.jpg, Image-AAC. jpg
Like this you will get 105 separated images each 1 frame long
Example correct padding : Image001.jpg, image002.jpg, image003.jpg
Like this you will get a 105 frames long sequence
Get this : or for mac
At this point i think you have three squences
A slice of color...
Resolve 11.1.2 - Smoke 2015 - Sapphire 8
Colorist / VFX Guru / Aerial footage nerd
© 2018 All Rights Reserved
