Difference between "Comp" and "Blend & Comp" Nodes
COW Forums : Autodesk Smoke
George Bellias
on Oct 4, 2014 at 6:28:11 am
I'm a little confused about the difference between these 2 nodes. When do I use one over the other?
George Bellias
Jade Productions
http://www.jadeproductionsla.com
Brian Mulligan
Re: Difference between "Comp" and "Blend & Comp" Nodes
on Oct 4, 2014 at 3:43:07 pm
The 2 sort of serve the same function. COMP used to be called LogicOps.
The only difference between the 2 is that Blend & Comp can have 2 sources(with mattes) and a background with blend modes and also color correction inside the node.
Comp just had 2 sources (with mattes) and blend modes. So it is a much simpler node for comping 2 clips over one another.
Here is a little more detail on Blend & Comp
http://www.premiumbeat.com/blog/smoke-nodes-blend-comp-blur/
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
