SMOKE ON MAC 2015 ULTRA-HD-monitor out only HD
COW Forums : Autodesk Smoke
Chris Jacobson
on Aug 27, 2014 at 6:54:45 pm
Interesting challenge with Smoke on Mac 2015 and Ultra-HD. You can conform, do all your vfx and render out no problem but you can not view Ultra-HD on your monitor from SMOKE. Smoke will only monitor output HD. Hopefully this is just an over site on Autodesk. Calls to them say they are working on it.....
In the meantime you will need to build your project, render out, then bring the files into another software application, like Resolve, to view you project on your Ultra-HD monitor.
Grant Kay
Re: SMOKE ON MAC 2015 ULTRA-HD-monitor out only HD
on Aug 27, 2014 at 10:45:57 pm
Hi Chris,
As far as I was aware, the current version of Smoke 2015 does not support 4K broadcast monitoring.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
