Change font in all text layers in one go?
COW Forums : Autodesk Smoke
Dave Boampong
on Jul 29, 2014 at 7:12:40 pm
Is there a way to select all text layers at once and change the font in all of them in one go like in FCPX?
Dave
Brian Mulligan
Re: Change font in all text layers in one go?
on Jul 29, 2014 at 7:25:53 pm
Select All button in the Text module and then pick a new font.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Dave Boampong
on Jul 29, 2014 at 7:54:39 pm
Thanks for that Brian but I meant if there are say 10 Gap Fx each with text applied, throughout the sequence and the client wants to change the font used, is there a way to select all Gap Fx or all Text Fx and change the font in all of them in one go? Otherwise one would have to enter each text effect and change the font one by one. Sorry for not being clear the first time.
Dave
Brian Mulligan
on Jul 29, 2014 at 8:42:48 pm
Ha.. sorry.. The answer then is No. you have to enter each effect and change it.
Brian Mulligan
Twitter: @bkmeditor
Dave Boampong
on Jul 29, 2014 at 8:45:19 pm
Neil Sadwelkar
on Aug 7, 2014 at 4:09:10 am
In FCP 7 when I had to do this I would export an XML of just the Text layer with the hundreds of text clips in it. Then open the XML in a text editor and alter all references to font then reimport it back.
Does Smoke import/export text in XML?
If you can, then check if the exported XML has a font attribute.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
