Change the pivot point/origin of an axis in Action
COW Forums : Autodesk Smoke
Daniel Burrell
on Jul 2, 2014 at 3:30:36 am
I am trying to rotate an object on the Y axis so it has a slow spin to it while it's on screen, but it appears to be pivoting from the right edge of the object (the object is to the left side of the screen). It's actually 3 things layered together and I have added an axis that controls all 3 of them to position and do the rotation. With the object pivoting from where it is now, it looks very unnatural, and I would like to move the pivot point more towards the center of the object. In Motion, this was referred to as adjusting the origin, but I can't find anything that jumps out at me in Action to accomplish this. Thanks in advance for any advice.
Daniel Burrell
Grant Kay
Re: Change the pivot point/origin of an axis in Action
on Jul 2, 2014 at 8:38:29 am
Hi Daniel,
In the object transform menu of axis, look for the centre sliders…. This will move the centre axis that you're after.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
