Change the size of a CFX Output
COW Forums : Autodesk Smoke
Daniel Burrell
on Jun 24, 2014 at 9:17:30 am
I am editing a HD video, and using SD footage in that video. I am just doing the kind of standard, blow up the clip behind itself and blur it to fill the screen. I had my original SD clip in place in the timeline, and I just created the CFX straight from that. I resized the clip, and got to the end of the line with the shot that I wanted, but when I made the CFX, it made it SD, so now I have a cropped output that is way too small. Is there a way to change the size of a CFX output once you have made it? And a second question, how do I set the size of a CFX output if I want it to be a different size than the clip that I am creating it with?
Grant Kay
Re: Change the size of a CFX Output
on Jun 25, 2014 at 7:33:25 am
Hi Daniel,
The CFX output is always defined by the clip you enter into ConnectFX with if it is a single clip.
However if you use a multiple clips or a gap clip, the resolution of the CFX should be set by the sequence.
See if that works for you.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
