What tool could I choose for a 25p to 24p convert job?
COW Forums : Autodesk Smoke
Jessie Weng
on Jun 16, 2014 at 4:49:52 pm
What's the difference between "Pulldown" and "Convert Rate" tools?
When I have to convert a 25p movie(with audio) to 24p film these two functions can also do the convert, but I wonder which one is the better way to do it?
Grant Kay
Re: What tool could I choose for a 25p to 24p convert job?
on Jun 17, 2014 at 7:41:31 am
The pulldown tools will introduce cadence or pulldown patterns into the frames. Its a way of managing the frames for different formats and frame rates.
The Covert tools do a straight frame rate conversion. You can either retime the clips or just change the playback rate.
Most people just take a 24fps clip and drop it into a 25fps timeline. There will be a timewarp with a slight speed increase but its really not noticeable and that should work for you.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
