Move a keyframe in the timebar
COW Forums : Autodesk Smoke
Daniel Burrell
on Jun 16, 2014 at 3:03:21 pm
Is there a way to move a keyframe on the time bar, without going into the animation screen and moving everything individually? I made a sequence too long, so I just need to make it shorter, and was hoping that I could just move all of the keyframes as one. I'm able to do it in the animation screen, but was just curious if there was a way to do it in the timebar.
Grant Kay
Re: Move a keyframe in the timebar
on Jun 17, 2014 at 7:33:18 am
Unfortunately not.
The time-bar only displays keyframes for the selected channel.
You can slip or resize a group of keyframes on a segment in the sequence but not individual keyframes.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
Daniel Burrell
on Jun 17, 2014 at 6:18:47 pm
I may have been unclear, I am looking for a quick way to move an entire group of keyframes from the timebar. For instance, when I make adjustments in one place, it shows up as one blue keyframe on the timebar, but it's actually potentially dozens of keyframes. Am I able to move those all as one from the timebar? Basically I want to move that blue line (keyframe) on the timebar, and every keyframe that it is representing.
Grant Kay
on Jun 18, 2014 at 1:41:11 pm
Unfortunately the answer is no.
Only through the animation editor I believe.
Regards
Grant
