Unreferenced Source Material Popup
COW Forums : Autodesk Smoke
Daniel Burrell
on Jun 16, 2014 at 1:35:29 pm
I am getting a popup every time I open a project now that there is unreferenced source material found, with options to recover or delete. Any idea what's causing this, and is there any way to see what material it is referring to? It has even happened on brand new projects, after I create the project on the startup screen and click go, it gives me that message. And I also can't seem to do anything to make it stop, Whether I hit recover or delete, I get the same message every time. Any help would be great, thanks.
Grant Kay
Re: Unreferenced Source Material Popup
on Jun 16, 2014 at 1:53:46 pm
Hi Daniel.
Go to these instructions and it should sort you out… Its applicable for Smoke 2015 as well I believe.
Good luck!
Check out the Smoke Learning Channel
Youtube -
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
© 2018 All Rights Reserved
