"Here's an easy one" or "banging head against wall"
COW Forums : Autodesk Smoke
Justin Gray
on Apr 8, 2014 at 3:31:22 pm
Simple keyboard shortcut question. I've dug all through the keyboard shortcuts and seem to be overlooking oneā€¦
I want to slide a clip frame by frame using a keyboard shortcut. I like to use the < & > keys. Alternately, holding down Shift modifier key in conjunction with the arrow keys could move the clip 10 frames in either direction. I know that "D" activates the Slide Tool but I still have to click and drag the clip. Is there a way to simple select the clip the slide it frame by frame in either direction by tapping a key on the keyboard?
What am I missing?
Thanks Fellow Bovines,
Justin Gray
Senior Editor/Motion Graphics Artist
Gray Planet
https://vimeo.com/grayplanet
Brian Mulligan
Re: "Here's an easy one" or "banging head against wall"
on Apr 8, 2014 at 4:00:04 pm
With the FCP shortcuts hitting D enters Slide mode and < and > nude the clip left and right. try creating a new user.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
