Greenscreen Keying Noise
COW Forums : Autodesk Smoke
David Koch
on Feb 28, 2014 at 1:55:16 pm
Hi folks,
i was shooting in front of a greenscreen. Blackmagic Pocket Cinema Camera on ProRes HQ, 1920x1080, 25p.
I am now working on it in Smoke 2013 and actually everything goes easy and well. But there is one big problem: noise and grain avoid a perfect result. When i have a look at the matte in a still the key and the fill looks good. The person is pure white and the background is pure black. But when the pictures start to move you see it guttering/pumping/moving at the edge between black and white (or the key and the fill).
I guess the problem comes from the natural grain of the camera itself, because it was shot and lightened well.
I did some research already, but especially in Smoke i didn't saw any helping posts so far. Would be happy about your answers!
Best,
David
Grant Kay
Re: Greenscreen Keying Noise
on Feb 28, 2014 at 2:38:04 pm
Hi David,
You should be able to detrain or denies the green screen plate to remove the noise/grain.
Once you have done your composite, you can always return the grain back into the composite using the regain node in ConnectFX.
Hope this helps.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
Joel Osis
on Mar 3, 2014 at 1:47:11 pm
this might help with edge artifacts and noise
http://www.joelosis.com/2013/01/yuv-blur-key-helper.html
w: http://www.joelosis.com
e info@joelosis.com
Sascha Haber
on Mar 4, 2014 at 7:55:34 am
Hey, guys...
Loving your quick tips videos.
One request :
Can you maybe superimpose the key combination you are using ?
I understand it makes us look smart in front of the client at a later point but for the learning point its a little to confusing
A slice of color...
Resolve 10.1.0.021
Colorist / VFX / Aerial footage nerd
http://vimeo.com/saschahaber
Grant Kay
on Mar 4, 2014 at 8:04:45 am
Are you asking for the ConnectFX schematic with connected nodes? or the modular keyer?
Sorry, I am not sure what you mean by combinations.
Regards
Grant
David Koch
on Mar 4, 2014 at 5:34:47 pm
Thanks so far, guys! :-)
@Grant: I already tried to reduce the noise with my favorite noise reducer called "Neat". But the problem still exists.
@Joel: This tutorial seems very helpful. Will try it out and let you know if it worked!
@Sascha: You are everywhere on the net! :-) I used the "MasterK" in Timeline FX / Axis. Works best for me so far. Already tried the other ones (RGB, YUV, etc) but "the Master" is just the master.
