can't import file in File in smoke
COW Forums : Autodesk Smoke
Tsai Ted
on Feb 26, 2014 at 6:47:00 am
Dears,
We import File (DPX,TGA) in Media Library.
Than anyone image is black.
That We create new colour Bar to test.
Than We got a message. please see attached file.
This message is
"COLOURFRAME: Could not allocate clip: Some elements(s) were not allocated ( allocated 0/1)".
How can we do ?
Thanks.
Robert Adam
Re: can't import file in File in smoke
on Feb 26, 2014 at 2:01:05 pm
Hi.
Can you please zip up the /usr/discreet/log and /usr/discreet/sw/log folders and upload them to the forum? (click the floppy disk icon when you reply).
I'll look through the logs and see if there are any additional error messages that might help identify the issue. So far it sounds like a storage or stone+wire database issue. Is your storage full?
Is the "cache source media" option on when you import? If so, try with that option off.
You could also try creating a new project and see if the issue still occurs.
Regards,
Robert.
Autodesk Flame and Smoke Support
http://www.facebook.com/AutodeskFlame
http://www.facebook.com/AutodeskSmoke
Tsai Ted
on Feb 27, 2014 at 2:09:09 am
Hi Robert:
Thanks for your help.
Your Message that let me know more and more.
I found some message about "Permission denied", So I use chmod to change the media store Permisson.
And I found another error message in log that I don't understand any more.
Please help us. Thanks a lot.
7163_discreetlog.tgz.zip
7164_discreetswlog.tgz.zip
Robert Adam
on Feb 27, 2014 at 3:03:26 pm
Hi.
Have you seen any improvement after having fixed permissions on the media storage? The logs indicate that permissions on /Volumes/A08S-14TB-04/ManagedFolder0 are the reason why Smoke can't create the frame files and .mio (source clip metadata) files.
What was the other error message you were concerned about? I did not find any other notable errors.
Regards,
Robert.
Tsai Ted
on Mar 5, 2014 at 3:08:33 pm
Hi Robert:
Sorry for late.
I see the message
"smoke20132_smoke1_app.log.8:[error] 1891466432 projectUtils.C:5555 02/25/14:17:24:13.208 PRJMGT : Failed to open database file /usr/discreet/project/project.db: No such file or directory"
Because we install the new OS and Smoke.
I see some error in this log, and is it normal?
Best Regards,
Ted.
