Animate Input switches .. possible ?
COW Forums : Autodesk Smoke
Sascha Haber
on Feb 12, 2014 at 1:52:25 pm
Hi guys..
I am trying to limit my render times on 4k projects and I figured out a Blend node does not need any computation time when its inputs are disabled.
Because I am building very classic node trees, this would really be easy to animate the on when I need the upper tree and turn em off when I dont.
Footage.......Footage
FX...............FX
FX...............FX
FX...............FX
BLEND......BLEND.......Output
Is there a way to animate the Inputs activity od do I need to do this by limiting the source footage in time ?
A slice of color...
Resolve 10.1.0.021
Colorist / VFX / Aerial footage nerd
http://vimeo.com/saschahaber
Brian Mulligan
Re: Animate Input switches .. possible ?
on Feb 12, 2014 at 2:58:17 pm
What version are you working in? Mac or Linux? In 2014 Linux you can use the MUX node, which acts as a switcher that you can keyframe the inputs.
In 2013 MAC you can use a Matchbox node which also has a switcher effect you can load.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Sascha Haber
on Feb 12, 2014 at 3:33:52 pm
Hi Brian, thanks for you post.
But I was not looking for a way to switch inputs, I was looking for a way to disable the Blend node so it does not compute the upstream tree.
I tested the switcher and its handy, but it doesnt change the render time.
The Input Index is the one i can animate, right ?
If i could animate the input selector it would work though..
A slice of color...
Resolve 10.1.0.021
Grant Kay
on Feb 12, 2014 at 11:38:34 pm
Unfortunately, it is not possible to animate inputs on and off.
The switcher suggestion might work but not ideal.
I'll put forward a suggestion to rather optimise the processing pipeline rather than disable inputs.
Sorry I couldn't be of more help.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
Sascha Haber
on Feb 13, 2014 at 3:25:03 pm
Oh no...if Grant is out of ideas, we are doomed :)
Thanks...the easiest solution would be to just link it to the Transparency slider.
When its 0 it could automatically disable the upstream tree.
As soon as it blends the slightest bit it could start.
Thats how i know it from Fusion..
I actually moved most of the comp from 2D to 3D today and instead of 2 hours it renders 15 min.
Aaaaaaaand ACTION !
A slice of color...
Resolve 10.1.0.021
