Two-frames transparency animation problem with motion blur
COW Forums : Autodesk Smoke
Thiago Ferreira
on Dec 23, 2013 at 7:46:37 pm
Hi all,
I'm using Smoke 2013 on two machines and both present the same error.
I'm doing a transparency animation from one frame to the next, from 100% to 0% or 0% to 100% (to show or hide an image in my comp) AND turning on the motion blur (because of other axis animations).
But a hard cut doesn't happen. The render shows the next (or previous) image in transparency (something like 5 or 10%), as if the motion blur calculates image transparency animation of one frame to another.
I never saw that before. The motion blur should be active just in axis animation, not image transparency.
Anyway, I'd like to hear from you guys, because it is really giving me more work than before to sort it out, like separating in two actions, to bypass this problem.
Thx!
PS: I'm sorry if I didn't make myself clear. Not a native speaker.
Brian Mulligan
Re: Two-frames transparency animation problem with motion blur
on Dec 23, 2013 at 7:52:09 pm
Try and set the keyframe Interpolation to CONSTANT to get your hard cut via Transparency.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Thiago Ferreira
on Dec 23, 2013 at 8:32:07 pm
Thanks for the reply.
I just tried that, the problem persists. Very annoying.
I also made an entire new simple composition where I get two images and make a simple transparency animation from one frame to the next, turn on the motion blur and I get the same problem.
Seems like a bug to me.
Joel Osis
on Dec 24, 2013 at 3:32:24 am
maybe your key frames exist on sub frames, have you tried selecting your key frames and choosing' frame snap' from the animation tools?
w: http://www.joelosis.com
e info@joelosis.com
Thiago Ferreira
on Dec 27, 2013 at 12:15:39 am
Thanks but no success. The keyframes are in integer frames.
Is it just me? Anyone experiencing this render error?
Otherwise I'm pretty sure it's a bug. I never saw that in previous versions.
