Audio exporting with Echo
COW Forums : Autodesk Smoke
Daniel Burrell
on Nov 21, 2013 at 10:10:48 pm
I am trying to export the final master of the project that I've been working on, and when I export it, there is one spot where the voiceover has about a 1/2 second echo for just a couple of seconds. It doesn't do this in the timeline, only when I export. I have exported 3 different times, in stereo and mono, with the same result. Right now I am trying to export with the gain moved up to .05 (just so it is changed to something) and I moved the audio to a new channel. We will see if this fixes it, but I was curious if anybody has had this problem before. every once in a while when I was editing I would get a kind of wierd audio echo, but when I would rewind and play it again, it didn't do it, but it's in the exact same spot every time when I export.
Any ideas what's causing this?
The audio that's echoing is a WAV that was recorded in our booth in adobe encore. The other audio in the program are AIFF's from sonic fire pro and audio from a Sony EX3 and Blackmagic Cinema Camera.
Daniel Burrell
