Audio Scrub Woes
COW Forums : Autodesk Smoke
Justin Gray
Audio Scrub Woes
on Nov 21, 2013 at 4:39:05 pm
Hello.
So my problem is two-fold.
1. When activating Audio Scrubbing from the timeline Options menu it only activates scrubbing in the timeline. There is no scrubbing in the Preview Monitor.
2. I like to map my scrubbing to Shift-S so that I can quickly toggle it on and off. No matter how many times I set this in the keyboard shortcuts the shortcuts will not take.
Any ideas?
Thanks Fellow Bovines,
Justin Gray
Senior Editor/Motion Graphics Artist
Gray Planet
https://vimeo.com/grayplanet
Brian Mulligan
Re: Audio Scrub Woes
on Nov 21, 2013 at 8:02:33 pm
1. Yea, it does't work in the viewer.
You can JKL with (FCP hotkeys) Hold K+L / K+J and you can scrub that way
2. The scrub isn't a toggle... it's a modifier key with a click.
it seems that the default ALT+click is easier than SHIFT+S+click.
But to set a hotkey, press set and then SAVE and confirm.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Justin Gray
on Nov 22, 2013 at 2:51:52 am
Thank you Brian. Yeah the ability to toggle it on or off would be great.
When I use to cut on Symphony I set the Caps Lock key as the toggle. Caps off no scrub. Caps on scrub
It was very handy.
Have a good day.
Justin Gray
Gray Planet
