Delete render files
COW Forums : Autodesk Smoke
Daniel Burrell
Delete render files
on Nov 20, 2013 at 11:32:07 pm
Is there a way to delete render files from a project? I have multiple projects that I have finished but I haven't archived, but I am trying to finish up a project and I'm afraid I am going to run out of space on the final render, so I am looking for a way to go back to these projects that I am not working with right now and clear out all of the render files. When I right click on a sequence, and go to media, it gives me the option to "flush renders", but that doesn't appear to actually do anything. Thanks.
Daniel Burrell
Brian Mulligan
Re: Delete render files
on Nov 20, 2013 at 11:34:19 pm
Flush Renders is what you want....but it's not instant. When You restart SMoke a background operation takes place called VIC (Volume integrity Check) This is what frees up the frames.
Flush renders... then shut down smoke and/or reboot your mac.
You can also try hitting Purge Frames button in Preferences>Storage.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
