close gap without losing Sync
COW Forums : Autodesk Smoke
Daniel Burrell
on Nov 19, 2013 at 1:10:30 am
Is there a way to close a gap and have all channels shift down equally? Right now if I have a gap on channel one and I close it, all of my audio and video gets out of sync. Is there a way to fill a gap but have all of the vertical channels move with the channel that I am closing? Right now if I have to tighten up an edit 30 seconds into a 10 minute program, I have to zoom out and select everything past where I had the edit, and manually pull it back, which because of the way smoke behaves when I try to move multiple channels at the same time, can be a chore as well.
Daniel Burrell
