Wipe with Borders
COW Forums : Autodesk Smoke
Josh Spivack
Wipe with Borders
on Oct 29, 2013 at 7:24:55 pm
It astounds me that through my research and own trial and error, I've yet to find a way to add a boarder to a standard, left-right wipe. Is this really the case? I'd be doing this for a series of different shots, a reel being made using mixed formatting so going to a standard NLE is not in my best time interests.
After working with Action and using some great tools, I'm surprised that Smoke wouldn't be my friend on a much easier task. Hopefully, it is.
Josh
Brian Mulligan
Re: Wipe with Borders
on Oct 29, 2013 at 8:20:07 pm
Yep.. it's kind of stupid really. You can create borders using Action/Gmask/and a color frame. Genarts Sapphire Plugin also has a Wipe spark with boarders.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Josh Spivack
on Oct 29, 2013 at 8:39:57 pm
Thanks for info!
Mike Roy
on Oct 30, 2013 at 5:28:51 am
The smoke wipes are basically pre-animated gmasks. While you can't add a border within the same wipe setup, you can duplicate that wipe in the layer above it and edit the 'gmask' within it.
That's what i did in this archive... you can download it here :
https://www.dropbox.com/sh/rson5l20zt16fwm/Ip0Q3faOru
it's not large at all, just colored frames with the aforementioned wipe setup. Render it and you can see there is a line where i've edited the top-layer wipe.
If you want more eye candy on it, like a drop shadow or anything like that, you can make a ConnectFX gap effect over the wipe and go to town. Simply copy the axis within the lower wipe and paste its animation into any axis in your ConnectFX, and parent anything to it within an Action or 2D Transform node.
Always glad to help!
Mike Roy
_____________________________
http://www.mikeroyartist.com
http://www.smoketutorials.com
