Ignore Light in Action
COW Forums : Autodesk Smoke
Justin Gray
on Oct 7, 2013 at 7:36:02 pm
Hey there folks, the shop I work for has recently switched over to Smoke 2013. Since I'm still learning you may see many more posts in the near future.
Question, I have a composite made in action using a couple lights, 3D text, background and a basic camera move. I have placed a pre-rendered, (out of After Effects) partical quicktime that I'm using as a foreground overlay. How do I tell that partical overlay to ignore the lights in the scene?
I have placed it within the action because I want the partical overlay to have the same camera move as the rest of the Action composite.
Thanks Fellow Bovines,
Justin Gray
Senior Editor/Motion Graphics Artist
Gray Planet
https://vimeo.com/grayplanet
Sandeep Sajeev
Re: Ignore Light in Action
on Oct 8, 2013 at 7:00:33 am
Use Shift+L to switch to Light Link mode. Then draw a connection between the light and the surfaces you want the light to affect. This is a thin blue line. To have a light not affect a surface, hold Opt and then draw the connection. This will be a thin red line.
Press Shift+M to switch back to move/select mode when done.
Justin Gray
on Oct 8, 2013 at 5:52:04 pm
Thank you very much Sandeep.
Justin Gray
Gray Planet
Sandeep Sajeev
on Oct 9, 2013 at 5:55:40 am
You're welcome.
Just a heads up, if you're in a crunch and you need help/guidance then check out the Smoke forum on the Area as well. It's the official forum and there are more Smoke users who pop in there and can help.
http://area.autodesk.com/
I'm not saying this to diss the Cow, I love the Cow and owe it an awful lot, just pointing out another resource for you to tap into.
Best,
Sandeep.
Justin Gray
on Oct 9, 2013 at 2:53:02 pm
Thanks again Sandeep!
The Autodesk Area is my new home away from home. And for anyone else out there who's reading this thread The Smoke Learning Channel is a great resource too. Grant's tutorials are very clear and informative.
http://www.youtube.com/user/SmokeHowTos/videos?view=0
I've been grazing these pastures for about twelve years now and it has bailed me out more times than I can remember. Especially with the Avid and After Effects forums.
Sandeep, I just looked at your Autodesk Smoke Learning Resources posting on Area and I will share those links with the rest of my team.
A couple of weeks ago we had Quinn with Autodesk here at my shop and he was very helpful too.
Thank you.
Justin Gray
Gray Planet
