GFX card configurations
COW Forums : Autodesk Smoke
Danny Thompson
on Oct 3, 2013 at 8:39:56 pm
On my Resolve system I have a Radeon HD 5770 and a Quadro 4000.
Currently the 5770 is running 2 monitors, while the Quadro has nothing attached. AFAIK this is the setup that is ideal for Resolve.
I've read that the best system for Smoke is to have just a Quadro 4000. From what I've heard Smoke won't see a secondary GPU.
Can this setup be adapted to Smoke? Can Smoke be set to render on the 4000 while the 5770 does GUI? Or does Smoke need to share the GUI with rendering? I'd consider 2 4000s but it might require me to cannibalize another Resolve system built this way.
Brian Mulligan
Re: GFX card configurations
on Oct 3, 2013 at 9:02:34 pm
Smoke will only use the main graphics card for the system. That which is driving the UI.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Danny Thompson
on Oct 4, 2013 at 1:00:41 am
OK - so a more ideal config would be to have 2 Quadro 4000s - one for the UI & Smoke, the other for Resolve (when it's running)?
Sameer Shrivastava
on Jan 6, 2014 at 12:01:04 pm
Hi
Im quite late here.
I also know that smoke uses only 1 gpu, but in my MBP 17" it doesn't seems so
I had stopped the auto graphic switching forcing the smoke on AMD 6750M only
but this is what happens when i render
Here is the AGPM log on console. I have to enable logcontrol to get this. this console log is generated while a simple action stup is being rendered
07/10/12 4:00:17.000 PM kernel: AGPM: GPU = IGPU G-state set to 5 from 4, ControlID = 16
07/10/12 4:00:18.000 PM kernel: AGPM: GPU = GFX0 G-state set to 4 from 3, ControlID = 17
07/10/12 4:00:18.000 PM kernel: AGPM: GPU = IGPU G-state set to 6 from 5, ControlID = 16
07/10/12 4:00:20.000 PM kernel: AGPM: GPU = GFX0 G-state set to 3 from 4, ControlID = 17
07/10/12 4:00:20.000 PM kernel: AGPM: GPU = IGPU G-state set to 5 from 6, ControlID = 16
07/10/12 4:00:20.000 PM kernel: AGPM: GPU = GFX0 G-state set to 2 from 3, ControlID = 17
07/10/12 4:00:20.000 PM kernel: AGPM: GPU = IGPU G-state set to 4 from 5, ControlID = 16
07/10/12 4:00:22.000 PM kernel: AGPM: GPU = IGPU G-state set to 3 from 4, ControlID = 16
07/10/12 4:00:22.000 PM kernel: AGPM: GPU = GFX0 G-state set to 1 from 2, ControlID = 17
07/10/12 4:00:22.000 PM kernel: AGPM: GPU = IGPU G-state set to 2 from 3, ControlID = 16
07/10/12 4:00:23.000 PM kernel: AGPM: GPU = GFX0 G-state set to 2 from 1, ControlID = 17
07/10/12 4:00:23.000 PM kernel: AGPM: GPU = IGPU G-state set to 3 from 2, ControlID = 16
07/10/12 4:00:23.000 PM kernel: AGPM: GPU = GFX0 G-state set to 3 from 2, ControlID = 17
07/10/12 4:00:23.000 PM kernel: AGPM: GPU = IGPU G-state set to 4 from 3, ControlID = 16
07/10/12 4:00:23.000 PM kernel: AGPM: GPU = GFX0 G-state set to 2 from 3, ControlID = 17
07/10/12 4:00:23.000 PM kernel: AGPM: GPU = IGPU G-state set to 3 from 4, ControlID = 16
07/10/12 4:00:23.000 PM kernel: AGPM: GPU = GFX0 G-state set to 1 from 2, ControlID = 17
07/10/12 4:00:23.000 PM kernel: AGPM: GPU = IGPU G-state set to 2 from 3, ControlID = 16
07/10/12 4:00:23.000 PM kernel: AGPM: GPU = IGPU G-state set to 1 from 2, ControlID = 16
07/10/12 4:00:23.000 PM kernel: AGPM: GPU = GFX0 G-state set to 0 from 1, ControlID = 17
For me it suggests both GPUs are being used. Though GPU switching is disabled
And they are not utilizing at full power,
Full power as per the plist file is
Max power state =8 for gfx0
AND 15 For IGPU
Any suggestions? what actually is happening
thnx
SAMEER S.
