Certain files not showing up in MediaHub
COW Forums : Autodesk Smoke
Danny Thompson
on Sep 20, 2013 at 7:38:09 pm
I have 5 image files. The files have the same base name, with a numbered index separated by a hyphen, i.e. file-1.tif, file-2.tif, file-3.tif.
In the MediaHub only file-1.tif appears with a thumbnail, and its name appears as "file-". The clip is interpreted as a 5-frame video.
Can this behavior be disabled so that I see the files instead?
Brian Mulligan
Re: Certain files not showing up in MediaHub
on Sep 20, 2013 at 7:43:26 pm
Under the Format Specific Tab, switch to Image Sequence.. Under the Metadata button, toggle to Clip Options.
Then Change Sequence Detection for Frames. Refresh via the Gear mmenu to refresh the browser and it will show you frames.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
