Exporting different Ratio
COW Forums : Autodesk Smoke
Kenzi Parker
on Sep 9, 2013 at 9:26:18 pm
I've created a project in a 16:9 ratio but am using some clips that are in 4:3. When I export them they go out as 1.778. How do I export them at their 4:3 size (at 1.334)
Kenzi
Brian Mulligan
Re: Exporting different Ratio
on Sep 10, 2013 at 1:38:27 pm
Are you exporting an edit sequences? If so how are those clips displayed? That is how they would export.
Or...
Are you exporting single raw clips?
If so, in the export settings you can change the output size and aspect ration... at the bottom on the second screen once you pick a preset.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
