Smoke Issue
COW Forums : Autodesk Smoke
Kenzi Parker
Smoke Issue
on Sep 5, 2013 at 7:44:21 pm
When working in Smoke 2013 Ext. 1, I'm trying to archive a file. Every time I get an error that states: "error parsing table of contents". I believe that is because of a file that was imported that ended up being corrupt. How would I go about getting rid of the file. I tell Smoke to delete it upon startup but it never does. I also cannot click the file. I'm wanting to archive the project that I have but it refuses to allow this.
KNZ
Brian Mulligan
Re: Smoke Issue
on Sep 5, 2013 at 8:18:14 pm
That error is referencing the TOC (Table of contents) for the archive itself. Are you using the verify archive option?
Smoke writes some extra archive info at /usr/discreet/archive -- liek an html toc file. Is there an issue with writing to that folder? Permisions?
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Emile Gorissen
Re: Smoke Issue
on May 5, 2014 at 10:56:28 am
Hi Brian,
I had the same issue over here with one project.
All the others, no problem.
Seemd i had a corrupt bin in my project.
Solution, make a new project, copy all you need to the new project using the mediahub.
Archive with no problem
I know it is a late reaction, but you never know
GreetZZ
Emile
