Invisible shadow receiver object ..
COW Forums : Autodesk Smoke
Sascha Haber
on Aug 29, 2013 at 10:27:09 am
How do i do this in Action ?
I would like to project some text into a real scene and have a rock solid tracking, a shadow caster object and my lights set up.
Now i seem to overlook the setting to turn a second object invisible to it only receives the shadow casted by the text.
thanks for helping a semi-noob :)
A slice of color...
Resolve 9.1.4 , Smoke 2013 EXT
Colorist / VFX / Aerial footage nerd
Grant Kay
Re: Invisible shadow receiver object ..
on Aug 29, 2013 at 4:54:40 pm
Do you want the casting object to be invisible so that you only see a shadow being cast on a surface?
Or do you want the receiving surface to be transparent except for the shadow area?
If it is the first option, you should be able to turn off the visibility of the object in the geom menus.
If you want to hide the shadow receiver surface, you can simply turn it off. What you will need to do is output a separate shadow pass and recomposite the 3D shadow on top of the background with the object.
Slightly cumbersome but it works as expected.
Check out the Smoke Learning Channel
Youtube -
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
© 2018 All Rights Reserved
