24p to 5994
COW Forums : Autodesk Smoke
Chris Rainey
24p to 5994
on Aug 28, 2013 at 4:53:42 pm
I have renders from Maya that are animated at 24, not 23.976. So should I import the renders as 24, edit in a 23.976 sequence, then place that sequence into a 59.94 sequence and export Field 1? Sorry guys. Very confused as to the best workflow solution.
ChrisR
Chris Rainey
Re: 24p to 5994
on Aug 28, 2013 at 6:16:47 pm
Correction. I just spoke to my producer. I need 24p to 2997.
Grant Kay
Re: 24p to 5994
on Aug 28, 2013 at 10:47:03 pm
Sopeaking from PAL world so I might be wrong but would you not do a 3:2 insertion to push 24P to 29.97?
If yes, than you can do the 3:2 insertion by going to the TOOLS tab, choosing the 3:2 insertion module and applying it to the sequence clip to convert the whole sequence.
Other feel free to chime in ;)
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
Chris Rainey
Re: 24p to 5994
on Aug 29, 2013 at 4:54:47 pm
Hi Grant. 3:2 pulldown worked like a charm. Thank you.
