Copying elements and effects from project to project
COW Forums : Autodesk Smoke
Patrick Miller
on Aug 21, 2013 at 6:38:58 pm
Hello,
I built a slate for a project in Smoke and I want to copy the same slate in to a new project. Can anyone tell me if this is possible or do I have to create the same slate from scratch? Forgive me if this is super amature. I'm very new to smoke.
Sandeep Sajeev
Re: Copying elements and effects from project to project
on Aug 21, 2013 at 9:37:06 pm
You don't have to re-create the slate.
- Go into the MediaHub and select Projects from the top. This will show you all the Smoke projects on the system.
- Select your Project and navigate through the Workspaces/Libraries until you find your slate.
- Drag the slate into a Library in your current project.
This works for anything, sequences, elements etc. It's very cool.
Best,
Sandeep.
Patrick Miller
on Aug 21, 2013 at 10:46:26 pm
Ahhh! I see! Well that changes a lot of things! I knew there had to be a way.
Much appreciated, Sandeep!
