About Edit Menu
COW Forums : Autodesk Smoke
Paradis Paradis
About Edit Menu
on Aug 9, 2013 at 4:23:53 am
My Edit Menu (Save Proejct... Import/Export....Preferences) should be locate at the top , however, i am not sure what i have press, it relocate at lower part now. how i can put it back to the top? thanks!
Joel Osis
Re: About Edit Menu
on Aug 9, 2013 at 8:40:09 am
this setting is in the smoke setup utility found in the smoke folder inside utilities,
in the general tab change the menu bar from no to yes
w: http://www.joelosis.com
e info@joelosis.com
