3D objects from Photoshop CS6
COW Forums : Autodesk Smoke
Daniel Burrell
on Jul 25, 2013 at 8:16:00 pm
Photoshop has the ability to create 3d objects, has anyone been able to successfully export them from photoshop and use them in Action in Smoke 2013, where it is actually a 3d object and not just a flattened picture that looks 3d if you look at it straight on?
Grant Kay
Re: 3D objects from Photoshop CS6
on Jul 25, 2013 at 11:04:11 pm
If you are able to export an OBJ, 3DS or FBX model from photoshop, there is no reason why it could not be imported into Smoke.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
Brian Mulligan
on Jul 25, 2013 at 11:28:03 pm
You can export an obj... but that file is not loadable into Maya and it crashes Smoke. It will load into Cinema 4D and Cheetta 3d.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Brian Mulligan
on Aug 1, 2013 at 5:58:04 pm
An now a blog post that explains it all...with workarounds
http://www.premiumbeat.com/blog/using-photoshop-3d-layers-with-autodesk-smo...
Brian Mulligan
Twitter: @bkmeditor
Daniel Burrell
on Aug 1, 2013 at 6:20:53 pm
Awesome, I will definitely use that
