Deliverables in details
COW Forums : Autodesk Smoke
Sijo Joseph
on Jul 25, 2013 at 7:34:34 am
Any detailed tutorials on deliverables, smoke 2013?
Grant Kay
Re: Deliverables in details
on Jul 25, 2013 at 11:05:31 pm
Hi
Can you be more specific about deliverables?
The Smoke Learning Channel covers exporting in the Getting Started series but what exactly are you after?
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
Sijo Joseph
on Jul 26, 2013 at 7:49:20 am
Formatting and outputting to various broadcasters delivery specs on tape (HD/SD)
Thanks.
Sijo
Grant Kay
on Jul 29, 2013 at 4:25:56 pm
What you have asked for is a massively broad topic.
At the end of the day, you would be working at a certain resolution. You would than go ahead a reformat that for your deliverable and that is where the generalisation comes in. SD is not too tough because we are talking about PAL/NTSC, field dominance, pulldown and 4:3 or 16:9.
HD is much more complex with 1080i or 1080p, 720p, progressive, interlaced etc.
The best course of action is to have a list of specifics and we might be able to help because every broadcaster around the world has different requirements.
Regards
Grant
Sijo Joseph
on Jul 30, 2013 at 12:57:10 pm
Hi Grant,
I just need one example.
just want to know the process/workflow.
( mainly the dumping process to tape.)
For example, hd 1080 project,after finishing the work, I want to deliver it in tape to the client.
*very useful tutorials of yours in smoke channel.
thank you very much
regards,
Sijo
Grant Kay
on Jul 30, 2013 at 4:30:14 pm
Ah ok....
Well, this should be easy to explain in this post.
You need to ensure that your system is configured in the setup application to work with a specific VTR. You can find the setup app in the Smoke Utilities folder. Choose the VTR option and check the VTR you want to output to. Don't have Smoke running the same time you change settings in the setup menu.
So firstly in Smoke, I would ensure that the timecode matches the blacked tape you want to edit/write to. To change the timecode of the clip, select the sequence and choose reformat. Here you can enable the change timecode option and change the timecode.
Once all the timecode matches up, select the sequence clip and go to the file menu, choose Output to VTR.
This will launch the output window.
You need to ensure that all your external connections are correctly set up. In other words, ensure you have RS422 control for the VTR as well as the correct sync going into Smoke as well as the VTR.
You should be able to choose what you are inserting (video/audio/both). If all is correct, you should be able to output to the VTR.
Hope this is helpful.
Regards
Grant
