Copy with Handles
COW Forums : Autodesk Smoke
Aaron Barton
Copy with Handles
on Jun 26, 2013 at 5:45:43 pm
Hey guys,
So I have an edit with a shot I've color corrected. It has 2 seconds of handles and I need to export the shot with the handles. I also need it to have the shot's original timecode imbedded instead of the timeline's timecode. Is there a way to copy this shot into a folder with the handles included?
Aaron
Grant Kay
Re: Copy with Handles
on Jun 27, 2013 at 3:02:24 pm
hi,
Hold SHIFT+OPTION and drag the copy out of the sequence into a folder.
That will keep its colour correction and the handles. However you will need to trim the handles out fully if you wish to export the clip in its full length.
This should also preserve the original metadata in the clip.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
Aaron Barton
on Jun 28, 2013 at 5:06:41 pm
Thanks for the help, it worked perfectly!
