smoke back burner
COW Forums : Autodesk Smoke
Megan Beckwith
smoke back burner
on Jun 19, 2013 at 12:12:58 am
I am having problems with rendering out a video, it renders about 1min or less and then the back burner tells me it is waiting. Help!
Simon Modery
Re: smoke back burner
on Jun 19, 2013 at 8:47:42 am
I had the same problem. In my case it worked to export as a DPX sequence (instead of the H.264 I actually wanted). Then I just used compressor to finish the job.
Head of Postproduction
Motherlode
http://www.simonmodery.com
Megan Beckwith
on Jun 20, 2013 at 7:58:49 am
Thanks Simon,
I'll give it a go, if it works for you it should work for me.
Cheers, Megan.
Gustavo Bermudas
on Jun 20, 2013 at 4:17:29 pm
Actually there is a guide to solve this problem for good
http://area.autodesk.com/userdata/forum/m/mikes_backburner_guide_v4b.pdf
Megan Beckwith
on Jun 20, 2013 at 11:30:35 pm
Thanks Gustavo - that looks great. I have been trying lots of different things. The last effort was every time I use smoke I re install it. It works great for abut 2-5 hours, then it stops rendering, stereoscopic timelines stop working/layering. It gets progressively nasty! I think you may have solved my problem. Cheers, Megan.
