Video output locked to context
COW Forums : Autodesk Smoke
Sascha Haber
on Jun 14, 2013 at 10:52:52 am
Hi guys...
this might be trivial, but I can not find the right setting.
I am using a Decklink Extreme HD to output the video from Smoke and it works just fine.
But is it possible to lock the video to the Context 1 or 2 window ?
Or anything static ?
Right now it shows the node selected wich is helpful but a little confusing..
A slice of color...
Resolve 9.1.1 OSX 10.8.2
Colorist / Aerial footage producer
http://vimeo.com/saschahaber
Grant Kay
Re: Video output locked to context
on Jun 17, 2013 at 8:52:32 am
You should see a small MONITOR button in the viewer for all your outputs.
When you click ion this button, it sends that output to the viewer.
So if you want the CONTEXT 1 view to go to the broadcast output, switch the CONTEXT 1 view in Smoke and click the MONITOR button and that should do it.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
Sascha Haber
on Jun 17, 2013 at 9:14:44 am
Hi Grant,
thank you for pointing my in the right direction.
I actually had to switch to that mode in the preferences first.
It was set to the other mode and I could not find a monitor button :)
So if I would like to see my node tree in CFX on the left side, the active node on the right side and the Result on the video screen , I should switch to 3-Up and move the right most screen divider all the way to right , right ?
This seem to be the closest thing to get two working areas with a static output.
A slice of color...
