Project Sequence Recovery
COW Forums : Autodesk Smoke
Izzy Tamang
on May 29, 2013 at 8:16:50 am
Help! I just got done with the project when all of a sudden Smoke quit on me.
While trying to open it says "Corrupted BIN with the name "Sequences"" press Recover
Hitting recover opens the project but my sequence BIN/library has no sequences at all.
Sequence library is greyed out and my work is all gone.
Tried going to discreet/clip and import but have no idea how to recover my sequences.
As of now all my drafts, copies and final edit sequences are gone.
With FCP, Premiere pro and AVID I can open up the back up but with Smoke its out of my hands.
How do I get my project back?
THANKS MUCH!!!
Israel
Film/video Editor
SF/LA CA
Mike Roy
Re: Project Sequence Recovery
on Jun 3, 2013 at 7:00:38 pm
Izzy, did you get a resolution on this?
Did you have another hard drive connected when you crashed, and was it still showing in the launch screen when you started the program back up? Also, were you able to see your clips with their metadata, just no media in them?
Mike Roy
_____________________________
http://www.mikeroyartist.com
http://www.smoketutorials.com
Yoav Dagan
on Oct 25, 2013 at 9:38:39 am
hI
Did you resolve the issue???? I got the same problem, one of my Libraries is corrupted, this is a massive issue as I've put all the time-lines in this lib, can't get it to work, trying this 2 links but failed to understand the procedure correctly.. maybe someone can help with a layman lingo?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15678477&l...
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15580208&l...
Please replay
Y
Yoav Dagan
Colourist / Onliner
TiNT Post Production
South Africa
tintpost.com
