Renders Glitch Smoke 2013
COW Forums : Autodesk Smoke
Ronaldo Pucci
on May 20, 2013 at 8:40:35 pm
Hi guys,
Anyone saw some artifacts appearing in render.
I did some large CFX and in the result, some bigwhites blocks appears in my render result.
Anyone have the same problems ?
thanks
Ronaldo Pucci
Martin Gaumond
Re: Renders Glitch Smoke 2013
on May 23, 2013 at 1:31:48 pm
If it looks like a bunch of multicolored blocks randomly arranged in my experience it is simply a corrupted frame in the cache/rendered media. Empty/flush the cached media and re-render, it should go away.
Ronaldo Pucci
on May 24, 2013 at 3:17:51 pm
Yes, sometimes work,
But normally when the CFX is too big and I have a lot of actions inside nothing solved the problem.
Sometimes I can't click on the Render button, I came out to timeline and start click to the left for render frame by frame. A manually solution for the problem.
If I have more than 3 actions for example I have to disconnect the last one and apply this little guy on a upper level of my timeline.
Thanks for your help. I'll post a photo of my problem soon, when I get on my work
Stefan Coory
on Jul 23, 2013 at 7:35:55 am
Hey Ronaldo
We recently had a problem like this and turned out the Memory token was set to high not leaving enough ram for the OS.
Stefan
Ronaldo Pucci
on Jul 24, 2013 at 6:29:55 pm
hum....
But where I can do this action?
Sometimes when my comps (conectfx) have more than 3 actions, the results start show this problem, for many times I had to turn off some details for I can render this step without any problems.
Bruno Frede
on Jul 24, 2013 at 4:16:29 pm
I've had the same problem. I turned off Anti-Aliasing in one of my action nodes and the problem was solved! Don't know why, but it did!
Ronaldo Pucci
on Jul 24, 2013 at 6:32:04 pm
Is that possible the reason is because the Anti-Aliasing make the actions more heavy to render?
Bruno Frede
on Jul 24, 2013 at 6:39:50 pm
I believe so! But don't know why exactly! I just know it worked!
