How to Relink DPX media
COW Forums : Autodesk Smoke
Chris Tomberlin
on May 2, 2013 at 4:58:47 pm
VERY new to Smoke; really trying to do something here that I'm not quite prepared for. I got an archive from another facility. They archived the project but didn't send the actual media until later. I can't seem to find an obvious way to get the sequence to relink to the dpx files. I'd appreciate a quick "how-to" even in the form of a link to a tutorial. The wiki manual is not very helpful unless I'm searching incorrectly.
Chris Tomberlin
Color/Finishing
Outpost Pictures
Chris Tomberlin
Re: How to Relink DPX media
on May 2, 2013 at 9:02:08 pm
Found some resources and figured it out. Seems Smoke "re-links" by choosing the "un-link" command. Not really intuitive to my brain.
Chris Tomberlin
Color/Finishing
Outpost Pictures
Grant Kay
on May 3, 2013 at 9:31:45 am
Hi Chris,
Being dropped in the deep end is never fun but hopefully things always work out.
With regards to the situation you have had. When you restored the archive, the segments in the sequence never forget their original file paths. Even if they are separated from their original media. So when you opened the archive and restored, your clips were black or checkerboard.
The Unlink function is essentially unlinking the segment from its original metadata and not just media. So when you get the unlinked message, Smoke is now expecting you to point it to a new location/file to match and link with. Hence the workflow.
I am glad that you were able to figure it out.
Many thanks!
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
Joe Maurici
on Jun 27, 2013 at 2:34:47 am
Hi guys,
I must be missing something here.
I have the clip with the checkerboard as the thumbnail.
So i've right clicked and clicked, Media/ Unlink Media.
The thumbnail changes to "Unlinked Media".... Now what?
How to do I tell it the new file path?
Cheers
Joe
