A Question About Tracking
COW Forums : Autodesk Smoke
ahmed aborady
on Mar 21, 2013 at 12:02:49 am
i've a track in shot and want to use point tracker in autodesk smoke 2013 to simulate
object movement on Z axis
any ideas ??
Grant Kay
Re: A Question About Tracking
on Mar 21, 2013 at 8:40:17 am
Smoke does not have a 3D tracker to be able to track movement on a Z-plane.
However you can simulate it through scaling in the tracker.
Before entering the tracker from action or axis, you will see a few buttons below the STABILIZER button.
Turn on SCALE. When you go into the tracker you will have two tracker boxes.
You position them as far apart as possible.
When you do the track, the positioner data is taken from the first tracker.
The scaling is worked out from the distances between the first and second tracker boxes.
In most instances this will help you simulate the z-scale movement you are after after exiting the tracker.
Hope this helps!
Check out the Smoke Learning Channel
Youtube -
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
© 2018 All Rights Reserved
