Sharing Libraries?
COW Forums : Autodesk Smoke
Eugene Lehnert
Sharing Libraries?
on Mar 19, 2013 at 7:28:00 pm
Is it possible to share libraries with the Flame and the Smoke on the Mac?
Brian Mulligan
Re: Sharing Libraries?
on Mar 19, 2013 at 7:29:44 pm
Yes. Flame 2013.2.2 (20th Anniversary Ext2 Sp2) is the same as Smoke2013 SP2 (2013.2.2)
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Eugene Lehnert
on Mar 19, 2013 at 11:30:19 pm
Can Flame 2013.2.2 read ProRes?
Grant Kay
on Mar 19, 2013 at 11:44:47 pm
The lastest version of Flame can decode ProRes if you directly import the ProRes file.
However, I believe that when you wire between linux systems, the frame might be transcoded to uncompressed DPXs to ensure compatibility between Mac and Linux, even though the original was ProRes.
Autodesk technical support will be able to confirm this for you if you contact them directly.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
