Escape Hotkey into Gmask Schematic not working?
COW Forums : Autodesk Smoke
Nick Smith
on Mar 1, 2013 at 3:38:54 pm
I'm having an issue jumping into Gmask schematic via the Modular Keyer. I'm set up with the Smoke Classic hotkey preferences, and I should be able to enter into the schematic via escape key, but nothing happens. I go into the menu manually to change over. Any ideas?
Nick Smith
Color / VFX
http://www.finlandfinish.com/
Martin Gaumond
Re: Escape Hotkey into Gmask Schematic not working?
on Mar 2, 2013 at 7:25:37 pm
Is you mouse over the window portion you would like switched to the schematic?
Nick Smith
on Mar 2, 2013 at 7:38:46 pm
Yes. Even in the 1-Up view, I still can't switch over with the Escape key. It works fine in action, outside of the Modular Keyer. But inside the Modular Keyer, I can only switch over manually.
Nick Smith
Color / VFX
Martin Gaumond
on Mar 2, 2013 at 7:47:50 pm
Must be one of those quirks that smoke has. I too have certain problems that no one else has. For instance, i seem to remember that the escape to schematic works for me, but my mid-tones color wheel does not show the numerical offset yet it applies the offset.
Nick Smith
on Mar 4, 2013 at 6:14:31 pm
Ok. One more thing - Is there no more undo option inside of GMask? I hit undo now and it acts as a delete, which erases my mask. Frustrating.
Is this just another quirk isolated to me?
My prefs are set to Smoke Classic, btw. Also, undo works just fine anywhere else inside the Modular Keyer.
Nick Smith
Color / VFX
Martin Gaumond
on Mar 4, 2013 at 6:19:47 pm
No I have that as well.
The undo key in smoke classic is bound to the backspace and sometimes has the tendency to delete stuff. The work around in gmask at least is to undo via the edit menu. Also you can maybe re-assign the undo key to another key!
Hope this helps!
Nick Smith
on Mar 4, 2013 at 6:36:52 pm
Re-assigning works great. Thanks.
Nick Smith
Color / VFX
