Blade tool in smoke
COW Forums : Autodesk Smoke
Daniel Burrell
Blade tool in smoke
on Feb 12, 2013 at 7:15:49 pm
Still new to Smoke, is there a blade tool, similar to the one in final cut that you get when you press "B"? I have my shortcuts set to FCP7, but "B" doesn't do anything, and I searched through the keyboard shortcuts and was not able to find anything that looked like it. Thanks.
Daniel Burrell
Light Productions
Little Rock, AR
Brian Mulligan
Re: Blade tool in smoke
on Feb 12, 2013 at 7:17:13 pm
To make a Cut it's SHIFT+V
To make a cut through all layers it's CTL+SHIFT+V
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Ken LaRue
on Feb 12, 2013 at 7:18:37 pm
Damn Brian you are fast!!
Ken LaRue
Autodesk Smoke Technical Marketing Manager
Ken LaRue
on Feb 12, 2013 at 7:18:02 pm
There is no actual blade tool but using the short cut of Control V will create a cut at the current time positioner.
Ken LaRue
Brian Mulligan
on Feb 12, 2013 at 7:20:47 pm
Fast but not accurate this time.
Still don't knowmy FCP hotkeys.
Cut (Current Version/Track) Ctrl - V
Cut (All Versions/Tracks) Ctrl - Shift - V
Cut Around Selection (Current Version/Track) Shift - V
Cut Around Selection (All Versions/Tracks) Option - Shift - V
Remove Cut (Match Frame Edit) Option - Ctrl - V
Brian Mulligan
Twitter: @bkmeditor
Daniel Burrell
on Feb 12, 2013 at 7:23:06 pm
Awesome, thanks. You guys are awesome, and very fast. I know i've asked some basic questions the past few days, but you have been really helpful. Before smoke, I was jumping between FCPX and Motion, so it's a big jump for me, and a steep learning curve, but I think i'm getting the hang of it slowly but surely. Thanks again for all your help.
