insert/overwite/replace/append, etc. only places video
COW Forums : Autodesk Smoke
Daniel Burrell
on Feb 11, 2013 at 5:16:27 pm
In Smoke 2013, when i use the buttons to insert/overwrite/replace/append, etc. a clip from my source into my timeline, it only places the video track. In order to take the audio and video, I have to drag the clip from the source window to the timeline. Is there a way to toggle whether it takes everything or just audio or just video?
Daniel Burrell
Light Productions
Little Rock, Arkansas
Brian Mulligan
Re: insert/overwite/replace/append, etc. only places video
on Feb 11, 2013 at 6:08:53 pm
it should take it all. Are the tracks routed properly or locked?
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Daniel Burrell
on Feb 11, 2013 at 6:24:30 pm
As far as I know, everything is correct. It's a new project, and I haven't adjusted anything. Just 1 video track and 2 audio tracks. I am attaching a picture of my screen in case that's helpful. It has been like this since I Started using the program a month ago. If I manually drag the clip from the source window, it brings the audio and video with it, but if I use a button to place the footage for me, it only takes the video track. I have not adjusted or customized any of the settings that would affect this, everything should set to default settings.
Brian Mulligan
on Feb 11, 2013 at 6:28:33 pm
I'll bet your Source Audio tracks are mono. You can't hotkey or edit mono audio into Stereo tracks. You can drag and drop it. Which is dumb, I know.
You can only hotkey/edit like audio to like audio tracks.
Crate a new sequence and change it to create 2 mono tracks.
Or add to mono tracks to you existing seq and delete the setero one.
Then I think you will be fine.
Brian Mulligan
Twitter: @bkmeditor
