Smoke on Mac 2013 Autosave retrieve
COW Forums : Autodesk Smoke
Craig RussillRoy
on Feb 6, 2013 at 3:53:24 pm
Hi Guys
How do you get a old edit back, operator rotoscoping for hours - deletes keyframes by mistake and didn't undo .....
Where and how can you get back previosu backups - HELP !!
Fcpx
10.7
FCP 7.0.2
FCPX 1.0..4
3 x 4TB Thunderbolt R4
VC100
3 x ioXT
MicroHub
Ultrascope
SmartView
Check out the free iBook broadcast delivery 101 on itunes
http://Www.delivercommercials.com
Robert Adam
Re: Smoke on Mac 2013 Autosave retrieve
on Feb 6, 2013 at 4:28:05 pm
Hi Craig.
1. Exit Smoke, open Terminal and type the following command (replace [project-name] with the actual project name):
cd /usr/discreet/clip/stonefs7/[project-name]/workspace*
2. Now type:
ls -l *.clib
3. This will list all the folders in your project. You'll find several entries for each folder. The one numbered 000.clib is the most recent version of that folder. The ones named 001, 002 and so on are previous auto-saves of that folder.
4. Look at the dates and time of each previous auto-save of your folder and hopefully you'll find one from before the error.
5. Now back-up your current version of the folder just in case. Type the following command (replace [name] with the actual name):
cp [name].000.clib [name].000.clib.backup
6. Now copy the older version over the current one: (let's say you found that 003.clib was from before the error):
cp [name].003.clib [name].000.clib.backup
7. Close the Terminal and start Smoke and see if that brought back the lost work.
8. If you encounter any errors, corruption messages and such, you can restore the 000.clib file from the backup you've created in the Terminal:
cp [name].000.clib.backup [name].000.clib
Hope this helps.
Regards,
Robert.
Autodesk M&E Support
http://www.facebook.com/AutodeskMECF
Craig RussillRoy
on Feb 6, 2013 at 5:34:31 pm
And my first born will be called Robert, boy or girl !!
Thank you LIFESAVER
Fcpx
10.7
FCP 7.0.2
FCPX 1.0..4
VC100
3 x ioXT
MicroHub
Ultrascope
SmartView
Robert Adam
on Feb 6, 2013 at 6:15:45 pm
I'm glad it worked!
PS: please don't call your daughter "Robert" :)
Regards,
Robert.
Grant Kay
on Feb 7, 2013 at 2:07:03 pm
Roberta maybe ;)
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
Craig RussillRoy
on Feb 7, 2013 at 6:41:47 pm
see what you did there Grant ;-)
Fcpx
10.7
FCP 7.0.2
FCPX 1.0..4
VC100
3 x ioXT
MicroHub
Ultrascope
SmartView
