Using reference sources with the paint node.
COW Forums : Autodesk Smoke
Dustin Bowser
on Jan 28, 2013 at 11:22:16 pm
I'm doing some alpha painting with the paint node, and want to be able to see my original Front as a reference along with the alpha that I'm cleaning up.
I've got another source piped in using a new media node, which is the original footage source, and I have overlay turned on. Sometimes I can get it to work, and sometimes not. It seems like it's the luck of the draw. Perhaps it's a bug. I've been able to successfully get it to blend 50% my result alpha with my footage reference source if I switch the brush into 'reveal' mode, but sometimes it doesn't do it, which is why I'm posting.
Was wondering if anyone else has had any wonky behavior trying to use reference sources in the paint node.
Brian Mulligan
Re: Using reference sources with the paint node.
on Jan 29, 2013 at 6:33:00 pm
If you can post a full frame screenshot of the Paint you and the paint node connections, I can tell you in a flash.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
