Ctrl-Tab not working to switch to Nodes Bin
COW Forums : Autodesk Smoke
Dustin Bowser
on Jan 28, 2013 at 9:09:44 pm
For some reason on the Mac I'm on, the keyboard shortcut Ctrl-Tab doesn't work to toggle the FX Ribbon, the Nodes bin when in CFX, or the CFX schematic when hovered over the viewer.
I tried going in and making sure all the mac keyboard shortcuts were at their default.
I double checked in the Smoke Keyboard Shortcuts that Ctrl-Tab was indeed mapped, and it is. I tried to remap it to the same thing, but for some reason it won't take Ctrl-Tab as a key command. It will accept either Ctrl, or Tab, but not them together. Not sure why.
Ctrl-Tab is definitely working on the keyboard, as I can navigate Chrome and other apps using that command. Seems that Smoke isn't liking it.
Any ideas?
Brian Mulligan
Re: Ctrl-Tab not working to switch to Nodes Bin
on Jan 28, 2013 at 9:21:50 pm
Check the Keyboard Selected in the Keyboard Shortcut screen and make sure it is set to US English.
Also, it's SHIFT+TAB to activate the FX Ribbon on the timline under Classic hotkeys. And CTL+ESC to see the CFX schemativ from teh viewer.
But it is SHIFT+TAB to open the FX Node Bin.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Dustin Bowser
on Jan 28, 2013 at 9:36:18 pm
Yeah, it's set to Mac US English--
Actually, on Smoke 2013 using the Smoke 2013 (FCP) keyboard set, switching to the FX Nodes and such is with Ctrl-Tab. I use it all the time on another machine I use, but for some reason on this particular machine that I'm on now it doesn't want to work....
Dustin Bowser
on Jan 29, 2013 at 12:33:05 am
I think there is something up with the Ctrl functionality on this machine, because I also just noticed that I can't use Ctrl to select a clone source within the paint node. I can't find a way to select a source to clone from.
Anyone have any ideas of anywhere else to look to see what's up with it?
Grant Kay
on Jan 30, 2013 at 10:17:43 am
If you wish to clone a source, try using CONTROL+SHIFT instead of just CONTROL.
I know this was changed.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
