Don't see the Light or the Lens Flare FX Nodes
COW Forums : Autodesk Smoke
Stanley Little
on Jan 26, 2013 at 7:26:25 am
Hi All, inside Fx Connect or Action I no longer see the light node or Lens flare, it seems some other nodes are missing as well. Anty ideas.
Thanks. :)
Smoke 2013
Brian Mulligan
Re: Don't see the Light or the Lens Flare FX Nodes
on Jan 26, 2013 at 9:23:03 am
At the bottom of the node bins are reset bin buttons. If that doesn't work, you can create a new user. Although you can delete nodes from the bins.... You should still have everything in the ALL tab. I dont think you can delete from that one.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Stanley Little
on Jan 26, 2013 at 3:26:43 pm
I tried all above even reinstall Smoke and I'm still not getting a Light, Lens Flare or Input node. Confused?
thanks
Grant Kay
on Jan 28, 2013 at 12:01:23 pm
Make sure you Double-Click on the Action node to bring up the node bin inside of action.
You are probably still looking at the main ConnectFX node bin.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
