Smoke 2013 config
COW Forums : Autodesk Smoke
Yves Larivierre
Smoke 2013 config
on Jan 20, 2013 at 4:49:04 pm
Hello,
I just purchase Smoke 2013 i'm thinking on the best config. Two ideas with 2 computer.
1° MacPro 12 cores - NVIDIA 4000 - ATI 5870 - BM Decklink HD - EIZO CG245
For color grading is it a good idea to use the dvi monitoring option with my NVIDIA 4000 with the display port of the Eizo which is 10 bit. I've red osx could not handle 10bit ?
Or it's better with a Kona 3D but then how i could i use my Eizo as a broadcast monitor ?
2° New iMac 2013 with Aja io XT and a broadcast monitor like the JVC DT-R24L41D . Which is a 10 bit processing but 8 bit panel (i can’t afford a true 10 bit panel video monitor).
Any suggestions ?
Thanks !
