Gmasks
COW Forums : Autodesk Smoke
Craig RussillRoy
Gmasks
on Jan 9, 2013 at 10:19:55 pm
Hi Guys
I have officially gone crazy, Mac SMOKE 2013 - ok how do you make Masks non beziar ie non curves !
I was trying to do a rectangle mask and ended up with an Eclipse ... looked everywhere !
Fcpx
10.7
FCP 7.0.2
FCPX 1.0..4
3 x 4TB Thunderbolt R4
VC100
3 x ioXT
MicroHub
Ultrascope
SmartView
Check out the free iBook broadcast delivery 101 on itunes
http://Www.delivercommercials.com
Brian Mulligan
Re: Gmasks
on Jan 9, 2013 at 11:11:07 pm
Clikc on the Node... Select Node Prefs. under the preference tab there is a AUTO TANGET button. Turn it off.
Now create a mask.
You can also select the vertices after you draw a shape and when selected you can hit SPACE+B to Break the tangets. This way you can select some and not all... or select them all if needed.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Anders Utterstrom
Re: Gmasks
on Jan 9, 2013 at 11:27:39 pm
Hi, I learned some good stuff at smoke-training.com, episode #024. Check it out! You can combine bezier while deleting one or both handles for square corners all with key board short cuts.
Anders Utterstrom
Chicago, Illinois
Craig RussillRoy
Re: Gmasks
on Jan 10, 2013 at 5:25:37 am
Oh guys thnks a bunch, Ep 24 EXACTLY what i was after - Cheers !
Fcpx
10.7
FCP 7.0.2
FCPX 1.0..4
VC100
3 x ioXT
MicroHub
Ultrascope
SmartView
